It is time to move on from Easel to Vcarve. With Easel I just download the gcode and load it directly into the buildbotics controller, has been working fine for the year since I got my 1F.
Question will that work with vectric or do I need a post processor, and if so which one is recommended?
Would appreciate the help.
Tony.
You can find them here if you have 10.5 out below.
It also mentions if you have ver 11 they are included with the software.
@Sawdustmaker
Thank you, will be buying vcarve desktop & expect that they will supply the latest version. So from what you are saying it should be simpler than with Easel.
Could you also tell me if I can use Vcarve on two machines, I do most of my designing in the house and have an old clunker computer in the shop to run the 1F, With Easel, it does not matter which computer I am using the latest version of my work comes up on either one.
VCarve allows you to install on three machines
