SKH
(Stephen Harmon)
October 10, 2020, 3:58pm
1
I am having problems with the Vetric Laser driver. For some reason, the laser is not turning off between letters on a engrave so I get cutter path lines between the letters. Any suggestions on a solution?
Also, tried a photoengrave with several iterations on power and speed and all I get is a solid burn of different shades but no detail?
OnefinityCNC
(Onefinity CNC Official ✅)
October 10, 2020, 4:12pm
2
Post a pic your pwm spindle settings
SKH
(Stephen Harmon)
October 10, 2020, 5:28pm
3
I am not sure the VCarve driver gives me the option to get to a PWM spindle setting … could it be called something else in VCarve?
OnefinityCNC
October 10, 2020, 6:00pm
4
on the controller itself. Not in Vectric.
SKH
(Stephen Harmon)
October 10, 2020, 7:39pm
6
here are the settings that i just added … did not affect the laser …when i run the engrave routine it still burns the cutter path.
OnefinityCNC
October 10, 2020, 8:15pm
7
Are you using our vectric laser laser post processor?
SKH
(Stephen Harmon)
October 10, 2020, 8:18pm
8
Yes, VCarve 10.57 with the Vetric Laser Module and the OneFinity Laser Post Processor?
OnefinityCNC
October 10, 2020, 8:58pm
9
Try restarting the controller
SKH
(Stephen Harmon)
October 10, 2020, 9:11pm
10
I restarted the controller to no avail … the laser is still burning the tool path between the engraved letters
cabinum
(Stephen Cabinum)
October 10, 2020, 10:28pm
11
I can’t find a Onefinity Laser PP on Vectric’s site. Is there one posted here that I haven’t found? Sorry, been looking everywhere.
Skharmon
(Kelly Harmon)
October 11, 2020, 12:15am
12
It’s on the JTech Laser site
OnefinityCNC
October 11, 2020, 12:39am
13
the post processors are here
If you are running Vectric 11 or newer, these are built into Vectic and you do not need to download and install these.
Updated 6/17/21
Version (2.0):
Onefinity Laser (Inch) V2.pp (4.9 KB)
Onefinity_Laser_mm_V2.pp (4.9 KB)
Install these to use the Jtech Laser add on when using Vectric.
OnefinityCNC
October 11, 2020, 12:43am
14
send the vectric file to us at support@onefinitycnc.com and we’ll try it on our end. The settings you’ve shown look correct.
SKH
(Stephen Harmon)
October 11, 2020, 2:06pm
16
Please find attached the gcode as well as the Vectric file.Perez Cutting Board laser.crv (2.1 MB) Perez Sample full power.gcode (64.5 KB)
Skharmon
(Kelly Harmon)
October 13, 2020, 11:43pm
17
Any progress on running the files I sent?
OnefinityCNC
October 15, 2020, 1:47am
18
I ran the file and it came out perfect.
Under pwm settings on the controller, deselect rapid auto off and dynamic power. Hit save at the top left. Select none in the drop down list. Then reselect pwm spindle and recheck rapid auto off and dynamic power and hit save. Run the file. Let me know how it goes.
Stewie21
(Jason Stewart)
December 6, 2020, 2:55am
19
Are these still the working laser PP for vectric?
