QCW Fix Stand And Fixed Leg Kit
Turn your Onefinity CNC into a stand alone money maker. Don’t waste time and money building a flat table when you can use that time to make awesome things! The innovative design of the Onefinity give you the option to easily add a solid, compact table. In addition the unique deign allow you to place your vacuum and other things right underneath, saving a lot of space.
Already have a QWC, no problem, purchase just the The Fixed Stand Leg Kit, this allows you to turn you existing QCW into a solid stand for your Onefinity.
Both the QWC Fixed Stand and the Fixed Stand Leg Kit Feature a compact design and innovative wobble free, easy adjust leveling feet. Set-up is quick and easy making for a great addition to your Onefinity CNC.
Important: The Fixed Stand will go on sale November 28, 2022. First orders will start shipping in 3-4 weeks.
Be safe, be well, and stay tuned for our final announcement on Wednesday! :blush:
Sincerely
The Entire Onefinity Family
As always, if you have any questions or need assistance, you are welcome to reach out to us either by email at info@onefinitycnc.com or give us a call at:
1-888-717-4242.
I will move next year and I was debating to move with my (homemade) table or get the QCW but I did not need (or like) the wheels and the basic frame still required legs.
This is a nice alternative, I will look into it!
Do we get the options to secure from beneath or above?
Yes, it workes with any style qcw.
So wish this was available when I bought my machine. Now I have a Kreg bench with the QCW sitting on it. Maybe I’ll switch to this kit and turn the other bench into a work table :thinking:
Very nice accessory for those buying machines now.
Where do the controller and monitor fit into this setup? At first glance, you still need to either have a side table to accommodate those things. I guess you could mount the controller to the bottom of the wasteboard but you lose easy access to the stop function and still doesn’t solve the location of the monitor.
The controller mounts to the underside of the qcw when using it with the legs.
Thank you for responding! What about the touchscreen mount?
It mounts on the exact same spot, front of the rail. Definitely check out the qcw youtube videos we have!
Is there any significant advantage between the “secure from above” vs “secure from below” QCW top?
Hey Larry,
the advantage of “Secure from beneath” is, with self-drilling chipboard screws, you do not need to pre-drill anything into the wasteboard slats. But…
I find “Secure from above” better because you can leave your CNC in place when you attach the wasteboard slats. And regarding the holes you need to drill for the countersunk bolts, you can create a toolpath for a new wasteboard slat set and simply mill it everytime you need new ones and you can even cut the slats out all with your CNC machine.
When drilling the holes for the countersunk bolts for “Secure from above” by hand I suggest this:
Has anyone fitted wheels to the QCW fixed legs. I have a need to occasionally pull the QCW forward to tile longer projects. Due to restricted space in my workshop, I would like to fit wheels?
Somewhere on the internet I saw a square plug that goes inside the leg and allows for the installation of a caster on the legs
Onefinity QCW Stand Adapter Plate Only!!. This Will Come With 4 Adapter Plates the Casters You Will Need Are in the Description - Etsy
I have been looking, but have not seen anything that bespoke.
When can we expect the accessory kit for improved stability?
Onefinity released a heavy duty version of the fixed stand last fall. Has anyone tried that version? I’m about to buy the QCW and I’ve already got a big table, but I’m potentially moving my workshop to a place where I’d like my journeyman to take up as little space as possible and the heavy duty fixed stand seems to fix the previous wobbling issues.
I recently purchased an Elite Gen 2 Foreman model along with the QCW Foreman stand. I’ve had the machine for a little over a month now, and it has been a solid purchase.
Regarding the stand, it is built like a tank and made setting up the machine incredibly simple. After assembling the stand, I stood on top of the wasteboard to see how solid it was. There wasn’t any movement at all-it was remarkable sturdy.
I have been in engineering for over 30 years, and it has been a long time since I’ve seen a product built with this level of strength and quality. The design and construction are truly impressive.
I would highly recommend the stand.
Let me know if you have any other questions.
Hi Henke,
I did a set of posts recently on how I set up my workshop using the QCW without a heavy table and made it hinge up against the wall when not in use. I am very happy with the rigidity of the frame and stability!
I have done a dozen projects already and I am very pleased with this setup!
I have an Elite 2 Foreman with the heavy duty stand and would highly recommend getting it. I have not noticed any wobble or movement of my table. I would recommend making sure it’s level and all 4 feet are supporting equal weight.
The stand is very solid, but I do get some shimmy of the entire setup when boring holes. I’m hoping a little weight added to the bottom shelf will help it out. For now I’m running my boring operations at a slower speed.
