Hey everyone, I got the QCW all assembled and leveled and when I went to put the machine on it according to instructions, there’s a misalignment. The front is nice and flush (per instruction) but the back is misaligned so that the screws don’t want to go in. Here’s the front.
Mine is a perfect fit. I think the key to success is to manually pull the x axis all the way to the front, hand tighten the screws, pull x axis all the way to back and screws should fit perfect. Crank down screws and done.
Not to be too critical, but that seems like a 1/2 measure for something that wasn’t milled precisely. Will put shear force on the bolts holding the Onefinity to the QCW.
I’m having the exact same issue. I bought the frame because I didn’t want to deal with misalignment issues impacting the performance of the tool. Mine is offset by 1.5mm on one side while the other sides are flush.
Try loosening all bolts one both the front and back of the qcw. Then attach the Onefinity feet to the qcw, then tighten back all the loosened qcw bolts.
