QCW - New Version - Wheels?
Hi there -
This is my 2nd post ever. Has anyone put wheels on the new Gen2 QCW? Is it even a good idea in terms of alignment/tramming/etc if its moved? I ask because I am putting mine in a basement, and to maximize space, I would want to keep it close to a corner, but also allow for getting behind it when needed or move it for tiling. If I am not asking the right questions, I apologize! Thanks again for any advice.
More or less for maximum accuracy and just overall things going as expected…once you move it you would need to re-level the machine. Tramming shouldn’t need to be redone if you are level like you were when you originally trammed the machine. It depends on what kind of accuracy you are hunting for. So being on wheels ls ok but there would be some work needing to be done each time. Also the machine would probably move around unless you had a way to lock your wheels.
