Trying to choose between the QCW/ Stand or another work table. Elite Foreman enroute.
How stable is it for the motion?
Will be adding Spindle (future ATC) .
I’m I limited to space or fiction of multiple bits with the QCW or does bolting to work surface give me better options, more bits to work with the ATC? I have seen DIY, Kregs , and Rockler kits. I like to stay with same company on there accessories if they make them for products I buy. But, I’am not getting through enough info on the QCW/Stand.
You should check out some of the awesome tables people on this forum have made or other projects posted. I own the QCW frame and rolling stand. My work is done in a garage and I can’t just permanently dedicate the room to a CNC I need the ability to file it up and but it against the wall sometimes.
Though I noticed some of the other tables being designed are narrow at the base with a rotating table too for compact storage and something I might consider in the future.
As for now i like the stand, but as far as movement it does shake quite a bit but I have never seen an issue with the shaking impacting the cuts.
As already mentioned when you home the machine with a Z-20 slider you need to turn the screen or the spindle mount will smack it coming forward. The bit is then pointed off the table. I put a grid on my spoilboard and I start carving 2" above for my first on the axis running along the y. I cut along that line so I’m losing roughly 2" of my 32" on the journeyman but if you use the edge of the waste board you lose roughly 1.5"
The stand is well built and you have have an Easier time mounting the rails in perfect alignment opposed to building your own. Though it all comes down to personal preference.
I really like your idea for the rotary install, as it allows you to still have access to the full cutting surface when not in use. Just need to remember to adjust the dust boot. I think i might try this vs, the replacing of the last slat that I am currently doing now…
