Does the QCW secure from above come with bolts for bolting the wasteboard onto the PEM nuts? If not, what size are they?
Yes. (Mostly, I was missing 3 washers and had 1 extra bolt.) The allen head socket for the wasteboard ones are a 1/8" and not the 3mm I expected (since it’s Canadian and they use that other measurement system). My 3mm allen key fit just a bit loose (enough that if you overtorque the bolt you’ll mess up the socket) but a 1/8" fit snugly with no play at all.
Jim - did they add holes to secure the QCW? My review unit didn’t have anything for the frame.
No. They have a hole under the corner blocks where some kind of threaded insert goes when you pair it with their leveling feet. There is no built in provision to affix it to a table.
You could add threaded inserts or revnuts and bolt it into the table from below. Or what I did was drill a 1/2" hole into the top of those corner blocks so I could insert a screw with a hex head and then used a socket on an extension to screw it into the table.
I started with a 1/8" bit and stepped it up to 1/2".
Hey Pete… Yes, both the “Secure from Above” and “Secure from Below” come with the necessary hardware to mount the wasteboard. Hope this helps…
