Can anyone tell me how come when I set up ramping in V carve it never ramps in at the same exact spot it’s constantly moving over and sometimes ends up ramping in on a curve
I’m not a v-carve user so I don’t know, but Fusion does the same thing. Why is it a problem?
This is normal behavior for Vcarve, if you need to start at some particular area in a closed vector you can click the “start” subtab just to the right of where you activated the ramp and set one of eight areas for them to start.
then preview your paths as Vcarve will preview exactly as it will cut. Save butt loads of wood.
