Vcarve pro and 3D question
I was wondering how you guys handle spots in carves that are to small for bits but go all the way thru the piece? I end up with little spikes all over the carve.
Curious
Thank you in advance. I’ve been avoiding true 3d carves because of this and figure it’s time how you guys take care of it.
Do you mind sharing a picture? I have completed a few 3D with Vectric (Pro and Aspire) and have not experienced the same problem.
Sure, I should probably get a better pic for it but here is a example.
Imgur
This is on the extreme side. All the proud spots should be cut all the way down to the bottom of the model. For some reason it just skips that part. I can pocket most them out but that just leaves a straight cut to the bottom when it should be modeled if that makes sense.
Imgur
That is what it looks like just imported. You can see the parts that cut all the way thru are the parts being left. Maybe I am just missing something obvious and this is something easy to fix.
