RapidChange ATC
@RapidChangeDon
Can you post your discord link here so our users can check it out?
Yes of course.
It can be unsettling at first. Once you get used to it it’s music to the ears LOL.
It was surely an out of the box idea that I never expected to work so well. I was just looking for a pick and place kind of semiautomatic for myself until I realized it tightened the nut sufficiently and then I became obsessed with making it available LOL
I have been checking the announcement threads and just now found this one so I will do my best to be involved
Made of plastic or metal?
If you have time can you check to see if spindle run out has changed over time. Idea just came to mind.
I guess the other potential issue is that the Masso on my elite does not have a connection to spindle control terminal block #7 do that would need to be added to spin the spindle in reverse.
Awesome on the integration 1F! Thought, make a foreman xl with a 50-52” x rail (also easy upgrade path) so you can still use the full 48x48 cutting area with the atc. Cheers on all the hard work and new products!
I just made my spindle run CCW, the wire for the #7 terminal is already there, it is white and taped off.
All depends what you have on the VFD end of the cable.
Pat
That’s great. I don’t understand why Onefinity would leave pin 7 disconnected. Anyhow, I find that the white wire is pin 5 on the connector at the bottom of the Masso enclosure. I ran that to REV on my huanyang VFD and still no CCW on the spindle. How/where did you connect the other end of that white wire?
thanks,
Jim
What is the largest Diameter bit that can be inserted in the ATC? I am looking for a new surfacing bit and want to get one that can possibly work with the ATC
Will Onefinity and MASSO be supporting the RapidChange Premium models that have a cover and IR sensor that ensures a successful tool change?
Also, is there an existing dust boot that works with a 80mm spindle and RapidChange Premium and does interfere with it’s IR sensor? (e.g. brushes get in the way)
Interested to see what Onefinity new dust boot will look like and hope that it does not interfere with laser mount.
Thanks
Onefinity will only support the Onefinity ATC Rapidchange model well sell.
Thanks that is clear but the question was does Onefinity plan to sell / support these other models that have features that make an ATC option something that you could trust to work in real world environment.
No, only the one we directly sell.
I know that this is currently on preorder but do you have any more information about the package? What’s included and how does it configure with the Elite series? I’m sure you are working on integration. Are there any videos showing seamless tool change?
