RealTime Redline Controller Firmware 1.4.18 (3/29/26) (Latest)
(Updated 3/5/26)
1.4.18 Firmware is now available for all Redline HMI and Realtime Controller controlled machines, plus Windows, Mac, and Linux!
Download Now: Downloads - RealTime CNC
Added
  • Download speed readout to software update dialog
  • Scroll buttons for file manager (Raspberry Pi)
  • Support for more touchscreen devices (Redline only)
Fixed
  • Software update check failing on MacOS
  • Startup units inconsistent if set to imperial and controller is already in imperial mode
  • Scaling issues on NumericEntry dialog box on MacOS
  • Font scaling issue on spindle warmup dialog when timer was started
  • Bug where some wireless gamepads could corrupt jog direction and cause missed steps resulting in machine position error
  • Bug where some wireless gamepads could interrupt system movements like homing or probing
  • Bug where rotary axis enable could be stuck in the enabled state
  • Bug where rotary acceleration units were not displayed correctly
  • Bug where some gamepads would not be detected on startup
  • M4 command not setting the spindle direction correctly on some VFDs
  • G28 not working in MDI mode
Changed
  • Improved motion smoothing of gamepad jogging at high speeds
  • Scaling and readability enhancements
  • Web interface improvements for weak or unreliable network connections
  • Improved network manager (Raspberry Pi version) and connections to 2.5GHz networks
  • Changed font size on file manager (Raspberry Pi) for improved readability
  • Updated web interface so all resources are served locally
  • Improvements to jump-to-line including better support for jumping to lines with arcs
