RealTime Redline Controller Firmware 1.4.6 (3/1/26) (outdated))
1.4.9 is now available:
(Updated 3/1/26)
1.4.6 Firmware is now available for all Redline HMI controlled machines!
Download Now: Downloads - RealTime CNC
Redline Raspberry Pi (arm64)
Added
  • Support for landscape mode and dynamic scaling
  • Defaults for OneFinity Apprentice Series
  • Support for middle mouse or wheel button panning in 3D plot
  • Icon next to software version to indicate software update available
  • Toolpath library folder can now be changed in SETTINGS/GENERAL
  • Scrolling file name readout for long toolpath names
  • Additional stages to spindle warmup
  • Spindle length offset reset button
  • Welcome wizard on first install used to load machine defaults
  • Support for M64 and M65 commands to control outputs
Changed
  • Remote QR code display now includes port number (8000)
  • Security improvements to file transfer via web interface
  • Support simultaneous connection of multiple clients in web interface
  • Improved uploaded file integrity checking in web interface
  • Web interface now shows file size in kB and MB
  • Machine defaults now include jogging speeds
Fixed
  • Bug where Windows permissions would cause crashes when loading gcode files
  • Bug where camera feed would not display on remote interface
  • Bug where step frequency in motor settings would not update when microstepping was changed
  • Bug where invalid characters in a tool path file could cause the software to freeze
  • Bug where continuous jogging would not obey axis max velocity
  • Bug where controller would not execute dwell commands directly following spindle commands
  • Bug where spindle override would cause tool change to fail
  • Web interface layout on mobile devices
  • Bug where work offset table would only display in metric units
  • Bug where jump-to-line would not work on some machines
I would like to know what version of Realtime do I have on my gen two delivered about two weeks ago. I have not opened any boxes yet, but I want to be ready with the usb stick and the update if I need it. thanks my order number was. 59728
thanks
You would have 1.3.10, the software previous to this one.
My order number is 59629 and it has still not shipped or at least I have not been notified. Now that we are at V1.4 are you planning to complete the batch 1 orders that did not have Redline interfaces in them?
Are we going to be getting an upgrade for elite masso gen 1 machines?
This firmware is for Redline Controllers.
Masso does it’s own firmware (5.13 at the time of this post).
When you turn on the HMI you will go to the icon with the 3 bars, then tap config. Select Network and add your wifi. Once connected, tap the 3 bars again and go to update. Tap download and it should tell you there is a newer version. Select it and let it complete the update.
i tried downloading the windows app is it a false flag for windows defender and also macafee (different computers) flagging it as a virus? it was downloaded from your site, just want to make sure
@LFwood Depending on our Windows security settings, Defender may flag the setup executable. We are working on getting it signed by Microsoft so it is no longer flagged regardless of security settings. In the meantime, if you ensure it is downloaded from our website (realtimecnc.com) it should be safe.
I just want to be able to select entire G Code folders and import/delete them :joy: Otherwise great machine!
I have a question: I have a redline HMI. It was delivered a few weeks ago. Should I download the latest software for it? I am still building my table and getting the space ready for it. So, I have not opened any boxes yet.
It takes about 3 min set up the network connection and to update once you have it set up.
Thank you for the update, now I see masso updated this 5.13 in November with this awesome new feature:
Feedrate Override up to 200%
Feedrate override can now be adjusted from 20% up to 200%.
Provides greater flexibility when testing, tuning, or adjusting jobs during operation.
