Recommended Temperature for the Onefinity CNC
We do NOT suggest letting the screen or controller being in temperatures below 40F. Condensation (and high humidity) can build inside and damage the electronics. This is especially bad for the touchscreen. LCD screens are filled with liquid crystal which can freeze. If your machine will be in an environment with temperatures below this, we HIGHLY suggest changing the environment it will be in. The best way is to keep the building it is in heated. If that’s not possible, Disconnect all wires/power cords to the touch screen and controller and bring them inside to a warm environment when not in use and bring them back when in use.
Humidity can also cause surface rust to build on the rails and silver metal parts. Please keep the rails lightly coated in 3 in 1 oil.
Failure to do so can result in the damage to the machine and electronics and can void the warranty.
Operating temperatures should be within 40-110 degrees F. Use outside of these temperatures may see your electronics fail.
What is the controller operating and Storage temperature range?
Operating Temp.: -30 ~ 70 °C or -22 ~ 158 °F
Storage Temp.: -40 ~ 70 °C or -40 ~ 158 °F
