Continuing the discussion from Rest Machining Failure: Back in April I reported a rest machining failure associated with 2 rest machining bits (1/16 & 1/32). I have since replaced my “brake stepper motor” & had installed ferrite chokes earlier with separated circuits to help eliminate any RFI issues. I have carved many pieces since without any further problems until this morning after I had shutdown Masso G3 last night to continue this morning as I have done many times before, guess what? I had finished the 1/8 (finish) and 1/16 (rest machine) carve last night and restarted this morning with the 1/32 (trest machine) toolpath when the spindle travelled to model boundary and plunged, I immediately stopped and shutdown! I went to Vectric Aspire program to see if perhaps the model boundary grayscale pixels were at fault, but all pixels showed no reason for Masso to tell spindle to plunge. When I carefully examined the 1/32 toolpath it showed the bit plunging the entire ONE side only of the entire model 4-sided boundary. For this project (wedding portrait) the profile cut vector is properly offset inside the model boundary, but regardless to say, I set the finish toolpath(s) to the model boundary. Why would Vectric software do this with its Gcode on one side and nowhere else? Again, all the pixel colors (no blackened pixels) of the boundary gave no indication for the bit to plunge so deep!
Has anyone discussed with Vectric why an operator cannot assign each rest machining bit to different limit boundaries (ex. model boundary & vectors)? Perhaps I am missing something simple I have overlooked in my journey with CNC’s. Any input would be helpful.
Thank Arnie
