Sanding letters after carving it out?
Hi everyone
Any suggestions on how to sand letters when they come out a bit rough? I do use a down cut bit. I even get a bit of the fuzzies when I use the 90 degree bit. Looking to clean up the inner part s of the letters, for the top just sand.
Thanks
I use a battery operated rotary tool. Does just right with a multi bit set to get in all the small contours of lettering.
I use [320 grit wheel for drill](uxcell Nylon Wheel Brush 320… https://www.amazon.com/dp/B07P2XQ2TF?ref=ppx_pop_mob_ap_share) and a razor blade to clear the fuzzies and get into the deeper carves. Usually I am too impatient to rerun the V tool path. When I do, it does a pretty good job too.
Thanks. I just bought it !! I reran the v bit as well
Thanks for everyone’s help.
What bit(s) are you using to get into the small areas? Most of the sanding drums I’ve found for the rotary are 3/8" dia and the burrs tend to be fairly course grits. Would like to find 1/8" 180/220 grit level drums/burrs.
