Ridges on bottom of groove using a bowl bit
I just made my first groove 2 in wide , 3/4 deep with a bowl bit. The bit left some ridges on the bottom, not real bad but still can feel them . any solutions for this? thanks
Decrease your step over (this will make the carve longer but require less sanding.)
ok i will try that thank you
May I also suggest roughing it out, then taking a finishing pass. Try a finishing pass of say 0.05".
That way any wood movement gets carved away.
Make sure your spindle is trammed to near perfect.
Pat
