my x rail on my elite journeyman has developed a grinding screeching sound when jogging from home position.
When was the last time you lubed her up?
I oiled the worm drive with some 3 in one oil. Seemed to help. Are there oil ports anywhere on the machine? I will be purchasing some white lithium grease today. Thanks for your response. Probably don’t have 10 hours on the machine. How often does it need lube?
Yeah, there’s a silver screw your x one is probably inaccessible behind the z plate
thanks Chris, found it.
