Shaper Trace - from Photo to SVG
Just in case you like to turn your paper doodles into vector SVG files - Shaper have a kickstarter for Shaper Trace.
If you know Shaper Origin (handheld/steered CNC router) - which uses “attachable” patterns to manage cuts (you become the x/y axis) they have now launched “Shaper Trace” a tracing frame with patters.
You put your frame over your doodle - and take a picture with their App - and the app converts your doodle into a size-correct vector SVG file. The software correct for camera angle and lens distortion using the patterns on the frame.
https://www.kickstarter.com/projects/shaper/shaper-trace-go-from-sketch-to-vector-in-seconds
I’m not affiliated - I just thought it could be a nice tool for any CNC’er. :slight_smile:
/k
Interesting.
I can understand a usecase for converting a photo or downloaded image to a set of vectors.
I dont see much of a use case of converting a hand drawn doodle to a vector file. I would draw the doodle directly in a vector package like inkscape or one of various phone and tablet apps.
Thank you for the link! I backed the project. It would be nice to take a drawing a kid creates and make it into something physical.
@AndyP do you know of any good tablet apps for hand drawing directly to vector format? I have a long standing need for this, but I’m yet to find any app with the level of smoothing required for my application.
Scan2CAD is the closest I’ve gotten, but is a bitmap to vector converter.
I think I see a different and beneficial use-case where Shaper’s Trace concept is more inviting to those who cannot use the modern cad programs:
  • Children that are barely starting to show a spark in woodworking (or making things).
This is a cool opportunity to turn a sketch or design into something that’s tangible rather than just a sheet of paper. I imagine that kids would only care that a design appeared on a piece of wood and they’ll want to do it again.
On the kickstarter page, they showed somebody converting a signature for use with CNC work, similar to how an artist would sign a painting. I suspect there’s a bunch more creative uses for smaller desktop drag-knife and laser machines; this may lower the software barrier for the crafty and less technical.
If you guys want some alternative, i made a software called shapescan.pt, and could work like shaper trace and even better.
If you guys want to try it i like that tou give me feedback
Cool! We will check it out!
Another great app that I use is adobe capture I started using it for Laser engraving converts anything easy into a svg plus has some other features.
