Simple warmup g code program for manual oiler
I made some changes recently to my WoodWorker X50 build, so wanted to modify the warmup routine I use to distribute oil throughout the linear motion components.
It is empowering to get back to manually creating a g code file, albeit a very simple one, while refreshing my memory on the various g codes and their uses/functions. I learned to add messages (MSG), and use them to pause the program at various points to allow the addition of more oil (I am using a manual pump oiler I had installed quite a while ago for the ball screw nuts). I am also adding oil to the felt wipers I designed and am currently testing on the Y rails.
The video is short, and provides the g code at the end. Here is the YT link…
