I had paused a 3D carve momentarily turned the router off to clear out some debris the vacuum did not suck out I hit play without turning on router the machine ran two seconds maybe without router spinning I had the skinny Jenny bit inserted the carve does not appear as good as usual tip of bit feels slightly rough that I ruin the bit can it be fixed yikes
Not as far as I know. Unfortunately, you’ll need to replace it.
you may want to ask Cadence Design. Bits can be sharpened, etc. Just not sure if it is economically viable.
I finished carve with a.063 ball nose after starting it again from point just before mistake saved carve I’m going to get ahold of cadence see if I can savebit
