Soft Alarm and Crashing on X Axis after upgrade
Hello, I have an Elite series journeyman (48x36)
I seem to have screwed up my machine a bit. Since the upgrade and stepper resolution upgrade my machine refuses to run programs that it ran before because of this soft alarm on the x axis.
If I disable soft alarms and run the machine slowly it moves to the far right and crashes, at least attempting to run the program. I tried reducing the project size from the 1200mm that I could originally cut down to 1150mm and same issue.
Does anyone know if this is a common bug, or if I need to tweak a setting in F1? I’ve read through their upgrade procedures a few times and I don’t believe I missed any steps.
Thanks
Our guess without seeing anything, is that either the dip switches are not correct and/or the config files didn’t take/wrong size machine was selected.
Try following the service bulletin again meticulously.
Reinstalled 5.07 and re loaded the settings. I have a easy setter but it’s not engaged yet.
Loaded the file again and it seems to be working as it should again. Thanks for the suggestion to turn it off and on again basically :sweat_smile:
#1 rule of troubleshooting :slight_smile:
