Squaring workpiece on spoilboard
What are some ideas of squaring your workpiece on spoilboard to ensure it is straight
Thanks
Mike
I made a grid with a Vbit. 2 inch seperation. Or you can use the laser.
I attached a guide that is removable. However I normally leave it in place. I usually use a 3/8 inch pine board to make the guide. I then trim the edge with a profile pass cutting the guide parallel to the X access. Then when mounting my work to the waste board I just but my work up to the guide.
If I remove the guide or it gets damage I just trim it parallel to the x to reinstall or repair it.
This is an example of what I use.
Mike
I’ve used both @MyersWoodshop fence on the table, as well as looking at the dog holes with bench dogs from RedDogWoodcraft on Etsy. I just got finished carving that, when QCW was announced. I think I’ll use the MyersWoodshop one for a while longer and tattoo it a little more, switch to the threaded insert/T-Track/Dog hole scenario, then QCW.
Like Cesar mentioned, I cut a grid with my v-bit. Tilt your work piece at an angle and rest it inside the v-bit groove so it’s aligned with the grid, then carefully pivot it down to the table. It should be square, assuming it didn’t move. And as Mike mentioned, I also install a fence as an alternate method, but I usually remove the fence once the work piece is glued down to help avoid cutting into my fence.
Can also put in dog holes, and use dowels as registration points(red dog woodcraft, etc)
