Grid lines on spoil board
Is anyone aware of a Vcarve file to create grid lines on a spoilboard? I have a machinist.
@laynemims posted one for the woodworker, but it would be easily modifiable.
what size grid you you want. i had 2" grid. i’ll mod it and send it to you,
Layne
Thank you. 2” would be fine.
You can easily design one yourself the way you want it. I made myself an 816mmx816mm x10mm grid that I laser burned onto my wasteboard.
Just curious if anyone has a recommendation on how to do a grid without a laser? I only know Easel but have my machine coming in just over 1 month. I will be doing a Myers threaded wasteboard but would also like having a grid. Just curious if anyone has done a grid without a laser. Thanks in advance!
Just use a 60 degree V-Bit with a shallow depth of cut, I just designed my grid today and am planning on cutting it this weekend.
-Alex
Hi Alex, thanks for the quick reply. How shallow of a cut would you recommend? Was in the process of creating a design but wasn’t sure how shallow of a cut is appropriate?
Would you mind posting a picture of the grid once you have it carved. I do not plan on getting a laser, and would really like to see how it turns out.
Thank you,
Tom
Are you using vcarve? Are there by videos on line showing this?
I did my grid line design in VCarve using a 60deg V-bit and a cut depth of 0.035". Here’s what it looks like.
To make the design I drew a single horizontal and vertical line that was 32" long and then used the array copy to replicate each of them across the board at 1in spacing. I didn’t go all the way to 32.25" because the resulting g-code file exceeded the limits of the machine because VCarve Pro wanted to move the cutter somewhat past 32.25" while re-positioning and I didn’t want to spend the time trying to figure out how to prevent it from doing that.
Martin
Morning @CNCNewbie Jonathan,
I was thinking of cutting to .025" but I will likely play with it a bit once I get to the OF. I see Martins success at .035" which looks great, so might start there vs .025" and then adjust.
@TMToronto , I’m happy to post up a few picts once its done.
@Jgolden4455 No I do not have VCarve, I use Easel for 95% of my work and Fusion360 for the delta. I just created a simple 2" x 2" grid to a 32" x 32" total coverage using Illustrator and “Saved As” a .svg which imported into Easel with ease.
Hope that helps!
-Alex
I posted a file of a 2" grid with numbers on the X and Y axis on the FB forum.
That’s might nice of you. I am patiently awaiting the arrival of mine. Just thought it was cool you offered.
That is very nice. I’m goin to make an attempt!
i was going to do grid lines with laser, but with vbit cut shallowit gives you something positive to line up to. easy enough to convert this to lightburn and laser on. i did the ruler and numbers in laser on mine.
I find that grid lines are finer and therefore more accurate to line up on.
Just got the Journeyman set up and wasteboard flattened. Now I am trying to make the grid lines. I got the file created in VCarve Pro, but when I go to create the tool path, I get an error that says Ignoring Unsuitable Vectors. 1 open vectors were identified in the selection and being ignored. There are 0 remaining vectors. I click ok and it will not create the tool path. I tried closing all vectors, checking vectors for errors, and get nothing. I created it by using the poly line tool and just making a 2x2 grid. Planning on using the 60 Vbit and have depth set up as post above. I have looked online and youtube for help, but am struggling. Anyone know what I am doing wrong? Thanks!
You’re running this as a profile toolpath right?
Like Josh said - make sure you’re using a profile cut. I also have a 2x2 grid (& #s) VCarve file if you want it.
