So far I’m using Fusion 360, but will probably lean on Carbide Create and/Or Easel as well. Can someone describe the process for drawing and cutting grids in the wasteboard?
I already downloaded Ben’s grid file, but not sure how to actually cut it.
Eric - you need to generate toolpaths in the CAM portion of Fusion (now called manufacturing), then export the gcode using a post processor, then upload the gcode to the machine to execute the op. You can likely use the Trace operation or the Profile operation in CAM.
Thank you Tom - looks like Trace with a negative Axial Offset will work for me.
