The Official 4th Axis Rotary, The Revolution
Great news, I’ve been throwing rotary carving to the back of my mind due to the fact that I would have to build a table that would accommodate it. No more. This mounts nicely to my QCW. What will have to be done to The Revolution to be compatible with the recent Masso resolution upgrade, the 2000 steps per revolution?
The Revolution will come with motor settings set to 2000prr.
Setup for the 2000prr will work, nice. Is there a promo code for the 15% offer? The prices for the Journeyman unit shows closer to 10% discount.
The discount is already reflected in the price.
Not sure if it was ever asked/answered, but will the QCW version of the Rotary work with the ATC QCW version?
Thanks in advance 1F…
So does anyone know of any 4th axis dust collection that works? Didn’t see too many ideas in a search. Do I just put a longer brush on my boot?
when will the manual be made public for the Rotary??
Looks like the manual for the Revolution rotary has now been released on the Onefinity website.
The instructions provide a process for manual switching back and forth from 3 axis to 4 axis configuration which involves configuring a couple of inputs, and changing settings for homing sequence and probing.
@OnefinityCNC would it make sense to just save a configuration settings file for each mode and just load the file instead of manually changing these settings each time? It would be nice if the Masso allowed the user to select the configuration file from the USB drive if there were multiple saved configurations. Thanks.
That would be an alternate way of doing things. Masso is… wonky when switching back and forth on this (a button like the BB controller is way, way easier).
We’ve found that sometimes swapping config files on the Masso doesn’t always take, then the screen is stuck sideways and you need to hook up a usb keyboard to fix…it’s a hassle.
Our way works, your way might work better for you… as long as either way get’s the job rotating! :slight_smile:
Did not test it, but I think beta 5.100b could be used to toggle between different profiles (configured as different users). You could then simply switch from “Standard” to “Rotary”
Hi, did you get your question on Rotary and ATC answered ?
I did. The answer was yes, however, since they did not ship the QCW attachment for the ATC due to quality issues, I had to install the ATC on the waste board. So as of now, the answer would be no. Waiting to hear back on the availability of the QCW mount. It has been awhile, so may reach out to them. Thanks for the reminder. FYI the rotary qcw mount makes things very simple and repeatable.
Thanks.
I’m in the exact same situation. So I’ve decided to design a QCW mounting support but I got stuck quickly. It’s not rocket science but , as of now, I’m not able to find a solution where the spindle can position the bit at the center of the ATC towers and there’s enough space for the rotary tailstock to slide freely for the entire length. Not enough Y travel, even with the spacer plate that comes with the ATC.
One option is to move the rotary system further in. But that will require new brackets and I’m not sure how the rigidity will get impacted.
Either way … it sounds like there is a solution but I didn’t find it yet. I’ll keep digging.
cheers, Alex
QCW mount (v2) production edition looks like it might arrive to us next week! We’re getting 300 in the first batch, so the first 300 should get their mounts soon(ish)!
This is awesome news… Wondering if I am in the first 300. I would thinks so, but not sure how to check.
