While trying to get my machine on a stable firmware update (1.3 definitely is not) I found that when I Zeroed my XY and Z, axis that they were off. I found what I thought to be the problem was in the Settings which OneFinity changed sometime along the way. But, that was not to be the case as when I check after editing the Settings to the actual measured Touch Probe block that they are still off by X 3.78 mm and Y 3.2. What’s up?
Related topics
| Topic | Replies | Views | Activity | |
| Touch Probe Problem? | 4 | 498 | March 9, 2023 | |
| Touch probe not zeroing xyz to material after probing | 14 | 1413 | April 7, 2022 | |
| Touch probe way off | 8 | 1192 | May 27, 2024 | |
| Touch probe out on X-axis (solved) | 1 | 427 | November 6, 2022 | |
| Touch probe issues? (solved) | 8 | 1886 | March 24, 2022 |
