When I probe for XYZ I get an incorrect X location, it is not at the bottom left of part? see pic. I have only noticed this since I updated firmware.
Hi Brent - which version are you using? 1.1.1? I can’t tell from he picture why X is wrong - it just says 0. It’s hard to tell from the angle, but I’m guessing the bit is too far to the left?
Hi Tom,
I am using Version 1.2.1, Yes X seems to be about 1" to the left of where 0 should be. This has only happened since I updated to Version 1.2.1. Thanks for your reply, is there a fix for this?
Brent
I’d check the values for the probe X and Y dimensions in the settings page to ensure they reflect the actual size of the probe block (in reality they should be close in value)
Hi Derek,
Yes I went through the process and measured my probe block and updated values to match. I ran the probe XYZ and still got the same incorrect results. Thanks for the feedback.
Brent
