I’m a totally newbie to the table top CNC. My machine is an upgraded original machinist with a pro journeyman X axis. So I’ve got a 16" Y axis and a 32" X. I just need the machine to be big enough to carve guitar and bass neck profiles out of aluminum. and this size should work… I hope.
Got a table built for it and have it set up… I’m having trouble homing the machine. I see there are standard settings for the stock machines but since this is an odd sized machine will I need to Stall Home all the motors?
Maybe I load a machinist setting and use them for the Y then load a journeyman and use those numbers for the X?
Thanks a ton.
