Trying to connect controller to Laptop
this is what happened:
Interface: 10.0.0.231 — 0x8
Internet Address Physical Address Type
10.0.0.1 10-56-11-75-9f-59 dynamic
10.0.0.243 38-9d-92-cf-df-86 dynamic
224.0.0.2 01-00-5e-00-00-02 static
224.0.0.22 01-00-5e-00-00-16 static
224.0.0.251 01-00-5e-00-00-fb static
224.0.0.252 01-00-5e-00-00-fc static
224.0.2.3 01-00-5e-00-02-03 static
239.255.255.250 01-00-5e-7f-ff-fa static
255.255.255.255 ff-ff-ff-ff-ff-ff static
C:\Users\Fiesta>ping 169.254.3.214
Pinging 169.254.3.214 with 32 bytes of data:
Reply from 169.254.3.214: bytes=32 time<1ms TTL=128
Ping statistics for 169.254.3.214:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 0ms, Maximum = 0ms, Average = 0ms
Hey Phillip,
I meant you need to look at the full output of “arp” command, the first part, which shows results for 169.254.3.214 interface. You had it on your first photo
@WaywardWoodworker Windows doesn’t have grep on its cli? for arp -a | grep "169.254" :slight_smile:
169.254.3.214 is your laptop
Ok i think im getting lost here. was i to ping my computer? This what i got back if so. So sorry I not a wiz on this type of thing.
Hey Phillip,
can you try arp -a again and prevent that the first lines of result get scrolled out of the window. The first lines of result that you had on your first photo showed two lists, one after the other. The one of interest is the first, not the second. Can you provide the first part of the output of the arp -a again?
Here’s both of them. sorry for misunderstanding.
C:\Users\Fiesta>arp -a
Interface: 169.254.3.214 — 0x5
169.254.255.255 ff-ff-ff-ff-ff-ff static
Hey Phillip,
okay! But unfortunately there has appeared no 169.254.x.x host. Next thing would be to doubt whether the Onefinity Controller correctly booted to the stage where network is configured.
Do you own a USB computer keyboard?
am i supposed to be doign this with no wifi? because its been on.
yes I do. I’ll get it and a mouse
okay but since you have no HDMI monitor it is typing blindly! But least you can use the keyboard to open a terminal window by typing <Ctrl-t><Ctrl-c> and then typing ‘sudo halt’ to properly shut the Onefinity Controller down, or ‘sudo reboot’ to reboot it.
It’s 23:17 in Central Europe. Got to go to bed now!
This happened:
C:\Users\Fiesta>
< was unexpected at this time.
C:\Users\Fiesta>
It’s cool. You’re amazing for helping me like this. So sorry I’m racking your brain. Get some sleep.
OF should really check their equipment before it goes out the door. Way less headache for the customer and I know support would appreciate it. Pull it off the shelf, test it, send it out.
Disabling WiFi is done because as long it is on, you have a default route and a DNS server entry pointing to the internet and all URLs you enter into your browser will be searched there in the first place what is not what you want when connecting the Onefinity without local configuration. But whether WiFi is enabled or disabled does not affect entering IP addresses.
Hey Phillip,
we have no evidence that it is the Onefinity Controller that is at fault. At least not at the moment.
As the others confirmed, it should work out of the box this way. What I would try next is to reboot the Onefinity Controller and check with “arp -a” on your laptop again to see whether a dynamic 169.254.x.x address appears.
A safe shutdown or reboot without a monitor and without a network connection could be made by attaching a USB keyboard to the Onefinity Controller, holding the Ctrl key and pressing the “t” key, then while still holding the Ctrl key down, pressing “c” key, and then after releasing Ctrl, simply typing “sudo reboot” (all without the quote signs). Note that a typo here might lead to unpredictable results :slight_smile:
ok, i’ll give that a shot thank you soooo much. Go to bed. I’m not worth losing sleep over.
space between sudo and reboot?
yes! :slight_smile:
:yawning_face:
how long to wait? Then do what?
repeat the test with arp -a from the laptop then
looks to be the same as before. Should I just wait for the monitor tomorrow and try that? hate keeping you up.
