Since i was replacing the Raspberry Pi controller I realized I was on 1.4.1. Once everything was working good and before reassembling the case I decided to update to 1.4.2. Usually I do it with the USB stick but this time I did it with the Raspberry Pi imager.
All went fine except there was a pre loaded G-code file. When I press the delete button nothing shows up to delete. I loaded a simple G-code program i created and now that file replaced it but it can’t be seen to be deleted. If I try loading another file, it adds onto the existing G code but still can’t be deleted.
When you press the delete button two headers show up “folder” and “files”. Under folder is “default”. Under files is nothing. I thought there was a way of manually deleting files but I couldn’t find it.
