i don’t know how many of you are using vcarve pro but there is an update from them fixing a nymber of issues i have seen talked about on this forum here is a list of what they fixed.
11.506 and here is the link as well. i hope this helps someone.
Fix crash in V-Carving toolpath
Fix issue applying ramps when tabs are present in Profiling Toolpath
Fix issue importing STLs with open faces
11.505
Fix ramps cutting deeper in the corners in Profile Toolpath
Fix relief artifacts when zoomed out
Fix STL importing issue
Fix circle form handling of comma
Fix Arc form not updating handles on apply
Fix Laser Fill incorrect Z start position
Fix ordering issue with the sheet list
Fix number of decimals in inch/mm in circle form
Fix translation issues
Fix rotary inverse time calculation with zero move in Roughing Toolpath
Fix issue with some DXF circles being polygonised
Fix Plate Production minor ui issue in some cases
11.504
Fix issue changing the flip direction in two-sided projects
Fix Surface Pro Tablet and touch screen handling in the 3D View
Fix printing 3D view with background image not respecting the option
Fix circle form updating of diameter/radius image
Fix home Z gap scaling in mm/inch jobs
Fix material misalignment when switching sides in a two-sided job
Fix a profile toolpath offsetting issue
Improvement to management, setup and display of custom variables in the tool database. A dropdown is presented to select preentered values for a variable. Existing variables will be displayed in the dialog to save on re-typing them again. Undefined custom variables will not be displayed in the tool name if they exist in the tool name template.
Fix some issues reading SVG files
Fix toolpath preview image saving as white in some cases
Fix excessive rapid moves in 3D Finishing toolpaths in some cases
11.503
Fix issue with importing .obj files from paths including multi-byte characters
Fix G93 inverse time calculation
Fix issue with undercuts not being displayed in the Import Model form
Fix issue with live preview being active when adjusting level’s base height
Fix non-driver crashes during rendering
Fallback mode for crashes in the graphics driver
Diagnostics improvements
11.502
Fix Moulding Toolpath sharp corner offsetting issue.
Update the simulation model in-between toolpaths when animation is switched off.
Fix ramped cut-through not showing up in the simulation as a cut-through.
