Jbmoore
(John Moore)
January 2, 2025, 11:28pm
1
Waste board for Woodworker using Fusion
Finally after much testing and the usual false leads and attempts, here is the final setup for waste board flattening in Fusion for the Woodworker. Link is to a Google Docs with detailed instructions for Fusion.
https://docs.google.com/document/d/1BwWZ4yWSCvClWdzwoP4A8kg3exqx1pxauuTrLGay1pI/edit?usp=sharing
Enjoy…
Timrf79
(Tim)
January 15, 2025, 4:17am
2
Thanks for the post.
It states to create a center triangle, I believe this should be rectangle.
The dimension, is that the size of the machine or size of machine plus 1/2 inch?
Jbmoore
(John Moore)
January 15, 2025, 8:35pm
3
Yes, that should have been rectangle… Brain fart… (corrected)
I used the dimensions as documented, I know there are references to 32 inches but I also found 32.5 inches in other docs… so…???
