Good day, I’m looking to build a table and wanted to pick the aluminum extrusions that would fit the onefinity Y axys table mount?
Hi Miles - I’m not sure what you mean by aluminum extrusions. Are you putting them under the feet?
These come in various series that vary by dimensions between slots. You can make a working table out of them. I could fasten the infinity to them but I need to make sure the distance between extrusion slots matches the distance between onefinity mounting holes.
Ah, I see. You would likely need two side by side or something really wide, which would be very expensive. Recommend putting something large and flat on top of the extrusions rather than attaching directly. Though someone where on the forum did build an aluminum table top, so I’d recommend digging around a little. If I find the post I’ll update this thread.
