When you have both ATC and revolution
Ok so though i do not yet have the ATC in my possession yet. It is coming.I need some advice on where I should position the ATC in this regard. I want it on the left side and in the y? axis. If you can, suggestions where the question marks are in this sketch.
ATC location with revolution.bmp (1.3 MB)
@HardtailSr While I’m sure you’ve put great thought into the placement… I’ve always thought preserving the full 48" of the machine was very important. Since sheets of plywood are 48" wide, it seems so common to load material that is 10x48, 24x48, 32x48, etc…
For this reason putting the ATC parallel to the rotary would be a good idea?
Your application may suggest otherwise.
I almost never use plywood but I did think of that my thought is if i wanted to “tile” something longer than my 32 inches I would not be able to with the tool changer in the way so this way I can still tile something and still use my tool changer…
