Which post processor for Estlcam?
Hi there,
Just getting setup with my journeyman and am trying to use Estlcam as I’ve used it previously. I selected GRBL as post processor but seems to be incorrect - i.e. carve is going crazy slow (unless its a units of measurement issue). Have been successfully using GRBL from Carbide create, so not sure what is going on.
Matt
Ok so answer my own question, the GRBL option appears fine - the issue was that I was using mm/s for feed rate where as the Onefinity expects mm/minute. Accordingly everything was crawling along! Easy setting to adjust in Estlcam.
