I took my machine apart to install my QCW and now when I try to move the or y axis it makes a loud shuttering noise I checked the wiring to-make sure I didn’t have some thing backwards the z axis works fine has anyone else had that problem or any idea by it would be doing this
Hey John,
did you check your machine is “squared”, i.e. the rectangularity between X and Y axes?
X/Y Rectangularity: The most simple methods
Also worth reading:
Agree with Aiph5u, your machine is likely not square.
Do not assume that the Y rails are the exact same length. Mine are not. Square from the front of the machine so when you home you are hitting stops that are square to one another.
