X Limit switch no longer lines up with new stiffy bar install (Solved, removed aftermarket x plate part)
Hi All, Looking for some advice. I just received and installed a Stiffy bar on my Elite Foreman Gen 1 and all went fine except the limit switch on the X-Axis is now slightly off and the little limit arm rams into the switch casing. Did I do something wrong or miss something?
Hi Jarod! it looks like you have some sort of aftermarket, 3d printed x plate. Switch to the factory metal plate that came with your machine and it should solve your issue.
i left the factory plate on and got longer screws
