X50 oil port Location
Hello, this may be a silly but I’m going through the oiling maintenance video and it says there’s an oil port screw on each of the y axis rails and one on the X axis. I have the X50 rail and cannot find the port. Is there something different on this, opposed to the 35 mm rail?
The following may be helpful.
I found that hole but there is no bolt in it. Is that how it’s supposed to be or is it missing?
The second link I gave - under the photo - is from a thread that discusses that. Seems some X50s shipped with a missing bolt, and 1F sent replacements in some cases. I would reach out to 1F support.
Thank you. I’ll do that.
Only one side of the block gets a bolt, the other doesn’t need it.
When I thought I had found the Y axis oil port on my X35 woodworker, I flooded (per Onefinity maintence video) it with oil and most of it ended up on my waste board. It was not coming out of the mouth of the hole. Was I using the wrong hole? Maybe flooding it was too much?
Thanks, Mark
