The Onefinity manual states that oil should be added to the oil ports of the ball screws periodically.
Where is the x-axis oil port on the X-50 Woodworker?
I can find the oil port screws for the y-axis but not for the x-axis.
Can anyone help?
Can anyone help?
looks like yours has fallen out?
Fallen out from where? I don’t see a hole.
unscrewed it self. Look at the link we linked to.
Thank you for the image showing where the screw should be.
There is a matching hole on the other side (router side). Should there be a screw there as well?
@Michael_M Thanks for asking this. Apparently I need to re-watch that video.
Cheers!
Paul
This is truly odd. It seems I’m also missing the screw. I wonder if this was an issue with the batch of machines because I’m quite certain this is how my X-50 Woodworker came (might have to find videos/photos to see if I happen to have a shot from an angle that shows it). ![]()
I had the same problem. It was missing when the machine shipped. Contact OneFinity and they will send you a replacement.
