Y1 motor I install set screw
Hi Everyone,
I’m in the process of installing my Elite upgrade on my Woodworker. I successfully installed the B1 motor. When working on the Y1 motor, I tried tightening the set screw in the collet to make contact with the flat surface on the shaft of the motor. But the screw bottomed out and stopped turning before it hit the flat surface.
It’s hard to see, but it appears that the threading for the set screw doesn’t go to the bottom of the set screw hole.
And suggestions would be appreciated.
Thanks!
