Z homing in wrong direction
I just got a woodworker pro with redline spindle. I have it assembled and powering up fine.
I noticed that after homing, my allowed Z travel is -17 to 0 mm. In the axis settings soft limit is something like -162mm.
When I home, x and y go in the expected directions ( left and forward) but Z axis homes downward. I can change axis direction so it homes upward but the +Y is down which doesn’t seem right.
All the examples and videos I see have Z axis homing upwards. What am I doing wrong here?
If your saying when you press z+ on the controller screen and the spindle goes down, you can check the box in settings to reverse z axes.
Hey Blake,
you might be interested in this and this
In any case you could first reset the machine settings under “Admin”.
Then if it still it moves into wrong direction, check z cabling / connector.
Welcome to the forum!
Figured it out. I had lowered stall torque because it was grinding but I think I lowered it too much. So when I had z going up like it should, it stalled right away. With torque value raised and axis direction corrected it homes now.
