Hi, I have an original X35 which I upgrade with a Z20 with a 80mm Spindle. To maximise the Z height I mounted the Z20 using the second mounting hole from the bottom. Unfortunately this resulted in having the SuckIt amrs being to short and leaving a gap between the shoe and the material. So I designed a longer one to solve this problem and wanted to shared it with whoever would like to make one. Attached is the 3D stl file that I’m sharing for personal use.
I used PLA for printing with a 25% infill and 3 layers all around and it is as sturdy as the original. The file is only for one side, use the mirror function to do the other side.
You will need qty 4, 6MM dia X 3MM thick magnet that can be easily found on Amazon or Ali Express.
You won’t need the bracket extension that comes with the Z20 but you will need to use the longer nub screws that comes with the Z20.
Be careful when you install them at the lowest position, as they can crash on the machine bracket when you home it (see end view picture). I used a zip tie to make a stop so that the left arm doesn’t go to low and crash (see picture with stop)
Thanks, this is great. The only thing is since I have the QCW, my surface is 1-1/4" lower, so I will have to modify it to be a tiny bit longer. I’ll have to be careful to put it higher when I home my machine.
Bonjour Luc, not sure if you are comfortable with Fusion 360 but will load the file if you want to modify from this.
The other thing not mentioned in my post is, my machine is mounted on 1 1/4 oak blocks at each corner, and added a spoilboard or 3/4 inch before surfacing flat so the machine is about .55 to .6 higher than the spoilboard. If you look at the picture Longer_Suckit_Arm_Installed, you zoom in under the orange Handle allen wrench you will see that .55/.6 step. I also used the longer bristle for the brush. So you might not need to modify it at all, but feel free do it.
Salut Pierre! Yes I’m comfortable with Fusion. Thanks for the file. I would have figured out how to modify the .STL but having the fusion file is way better. Alternatively I might just lower the slider by one position and that will get me there. I only need the full z clearance once in a blue moon. Before I saw you post I didn’t even realize I could use that dust boot with the 80mm spindle. I got the other suck-it dust boot that lowers with the spindle. it’s good for surfacing and thin material but the minute you want to go deep into a 3/4"+ material it get iffy.
Avec plaisir Luc! I would have gone longer but when I realize it would crash in the machine leg I stopped there. Depending on the job you do, it often goes back to home and some jobs my piece home is the same as machine home and would crash at the end of the cycle. By the way, I did struggle putting the magnets in I would make the magnet holes .010 bigger.
Salut Pierre, I modified and printed a longer version of your design. It works great! See the pictures below. There is no risk of crashing into the leg because with the QCW the leg is lower than if I were using a homemade table. As you can see in the pictures, if I use the longer bristles and set it at the lowest, it just kisses the spoil board surface. This will rarely be needed since it will 99% of the time be set for the surface of the stock. Only when surfacing the spoil board would that be the case, and I can switch to the other suck-it dust boot that attaches to the spindle for that.
I took the liberty of modifying your sketches so that they are fully constrained and parametric. But I will only post it here with your permission. I can put an STL and the .f3d as you wish.
Bonjour Luc, you have my permission to post. Glad that it brought you closer to what you wanted to do and you don’t have that interference problem. BTW not sure what you are using for holding you tube at the top but there’s a bracket on thingiverse that I used. If I would do it again, I would add a hook or something to hole the suckit boot when remove so its of the table.
My hose goes to the ceiling, and I have installed a tool holder to hold it up there. The tool holder cable tension can be adjusted a little to counter the weight of the hose, and that way it stretches out as needed. It’s been working great so far. That means I don’t need to put a bracket. Thanks for the tip anyway. As for the caps, the elite Gen 1 series already came with caps for the rails.
Like every shop owner, I’m never satisfied, and I will consider it a work in progress, but it is very functional. Grounding the pipes was a must. all that pvc pipeline with high speed air going through it. I got chocked a few times on cold winter days. not fun.
