m700
(george)
March 15, 2022, 1:55pm
1
My display registers my touch about 3/4" off. Is there a way to calibrate it?
OnefinityCNC
(Onefinity CNC Official ✅)
March 15, 2022, 2:16pm
2
turn the screen on 5-10 seconds BEFORE turning on the controller.
When connecting a touchscreen to the Onefinity controller there are a few key items to make it work correctly:
Step 1: POWER: Every screen must be connected to external (wall) power to operate correctly. Skipping this step is the most common mistake users make. On the 7 and 8" screens, the 12v wall power adapter must be connected to the 12v in (red arrow) port. On the 10", there is no 12v power input, instead, a USB C port labeled with a lightning bolt is used (red arrow). This cable must be …
m700
(george)
March 15, 2022, 3:36pm
3
Everything is hooked up correctly. My issue may be that the controller and display are on the same power strip I use to energize. I will correct this and see if it helps.
