10.8 touchscreen not working
I can not get the touchscreen to work. System works fine with a mouse, but…
Any ideas?
Hi Dave - welcome to the forums!
You mean when you touch the screen it doesn’t register but if you use a mouse connected to the controller it works fine? Seems like the screen is broken - recommend contacting support.
That’s exactly it. Was hoping I missed something!
Other than pushing harder or using a touch pencil, I’m thinking the display is fubar.
Sorry.
Double check that you have the usb connection from the screen to the controller plugged in correctly.
I would switch the USB C cords plugged into the monitor. Mine was the same and once I swapped them, the touch screen worked perfectly.
That is what I did and it worked. :smiley:
Thanks for the help guys. Switching out the USB cords did the trick!
