10" Touch Screen Blanking
I’ve been having the same problem and occasionally it will cause the program to stop running in the middle of a carve. I noticed that I would get a small static electric shock if I touched the gantry anywhere. The vacuum hose generates a lot of static and will hold it for a while after everything is shut down. I solved the problem by wrapping a piece of tie wire around the vacuum tube and then running it to a metal structure that is bolted to the floor of my shop. I’ve only run one small project since doing this but the screen stopped flicking off and the job ran all the way through 3 tool changes without a problem. Maybe try grounding your vacuum hose with a simple piece of wire.
Heres what i use
I’ve seen a few filters but not this one. Curious, what are the dimensions of this.
Thanks,
Tom
just curious if you have tried his monitor on your machine to see if problem is still present or not?
We did and it cycles on/off.
Display replaced. Working again
Probably about 3"x4"
Thanks for your response. I’ll check it out.
Tom
