Laser Not Firing - Looking for Diagnostic Ideas
I’m having an issue with my laser not firing at all. I’m running a 14W Dual Pro laser module on an original Woodworker Series machine. The setup worked fine for a while, then the next day the laser would no longer fire.
Here’s what I’ve checked so far:
- Machine powers up normally.
- Machine moves correctly and runs jobs as expected.
- Laser fans are running.
- All wiring has been checked and reseated.
- Wire continuity checks good.
- Controller power LED is on.
- Controller output/activity LED turns on when the laser is commanded to fire.
- Controller output/activity LED also turns on when I use the Full Power test switch.
- However, the Full Power switch does NOT produce a laser beam either.
- External power brick tests good at 12V+.
- Measured only about 0.11V to 0.22V DC on the two wires going to the laser module when the laser should be firing.
- I verified that my software’s S-Value Max matches the controller setting.
- No hardware or software changes were made between when it worked and when it stopped working.
At this point I’m trying to determine whether the issue is:
- Laser module failure
- Laser driver/power supply failure
- Controller output problem
- Something else I’m overlooking
One question: when checking the voltage at the laser connector, should I be measuring between the two power wires going to the laser head, or should I be measuring from each wire to ground separately? What voltage would you expect to see when the laser is commanded on?
Any ideas for the next diagnostic step would be appreciated.
