Hi guys.
I have the generation 1 Journeyman with a rotary A axis. Prior to Masso’s update 5.07 everything was working fine. After I updated to 5.07 I never checked the A axis operation, but did set the new steps per revolution on the motor configuration switches as per the update instructions.
Today I was checking out the rotary axis in preparation for a new job, and found when I include homing the A axis during initialization the machine shows a homing error. If I disable the A axis homing, the error goes away. I can jog the A axis just fine and I suspect it would carve correctly. I checked the connections and operation of the home sensor and verified to operate normally.
Did I miss something in the Masso 5.07 instructions? Has anyone else seen this perhaps under different circumstances?
