About the Onefinity Suckit Vacuum Hose and Router Cable Boom category
(Replace this first paragraph with a brief description of your new category. This guidance will appear in the category selection area, so try to keep it below 200 characters.)
Use the following paragraphs for a longer description, or to establish category guidelines or rules:
  • Why should people use this category? What is it for?
  • How exactly is this different than the other categories we already have?
  • What should topics in this category generally contain?
  • Do we need this category? Can we merge with another category, or subcategory?
There are a couple of different options to choose from when purchasing it from https://etsy.com/shop/rowdyroman
Some of you have asked what the clips are.
These clips have two advantages.
First: some customers do not have the luxury of having a designated vacuum hose for their cnc. Therefore the clips help with the ease of unattaching the hose from the boom.
Secondly: the clips have additional holes/clips to hold water lines if you go the spindle route.
If you just buy the boom without the clips you will zip tie (comes with purchase) the vacuum hose to the boom through specific holes in the boom’s joints.
Clip Sizing: Fein clips are 1 3/8"
Please let me know if there are any other sizes that I need to provide
Thank you for all your support!!
Hi
What would be the recommended internal height of an enclosure to accommodate the boom?
Thanks
Lee
Also looking for enclosure height for the boom if any has it.
Rowdy, I purchased a 3 hp spindle; 80mm; for my Forman. I expect to be using 1/2 in bits frequently. Is the 2.5 in dust boot going to be enough or would I be better off with a 4 in hose? Do you have options for either?
I think you can go either way and be happy. However if you are talking about the most efficient. Then with the right dust collector a 4” can be a beast.
And yes I offer both 2.5” and 4” clips
I have looked on your web site and esty store did not see the 4 inch. Maybe I didnt know what to look for or what I was seeing. I will also be getting the water cooling clips for both axis’s. Could you send me the link ps I am a newbee to cnc. I think I just saw the clips you spoke of. I would also need the dust boot or whatever the thing that encloses to spindle bit and shroud.the hose connect to.
