Good afternoon. TMToronto.
Many thanks for your helpful email, it’s very much appreciated. As you suggested, I’ve copied my machines current settings, although these are factory settings as a result of having to re-boot the machine due to the original X Drive Alarm problem, which, with the help of the support team, is now sorted (hopefully).
In the F1 screen all the homing sensor inputs are showing GREEN/Low and to RED/High when triggered.
I’m unable to screen jog any of the axis even when set to 100% and Continuous no matter which direction selected.
The Y axis was approximately 1/3rd distance from the front of the machine, the X axis was central, and the Z axis was somewhere in the middle.
Looking at my machine settings, I Have noticed that there is no figure for the Spindle spin up/spin down time and I’m pretty sure that there was a figure prior to the re-boot.
I’ve attached a copy of my machines, current settings, as suggested, so anyone who is a bit of a CNC wizard can have a look and hopefully spot where the problem lies.
Thank you so much for your help. Hopefully I’ll be able to start carving soon.
(attachments)
MASSO Settings v5.07 (G3-18883).txt (13.1 KB)
