Have you guys ran your dust collector, onefinity and your router on the same circuit? Any issues… hoping that onefinity chimes in
Jason,
There are may discussions that cover this on the Forum. Please do a search and I think you will find more detail than you ever wanted. Sort answer is its a good idea to separate them but please dive deeper to find out more.
-Alex
thanks for the reply Alex. I’ve read about it but I haven’t seen onefinity’s official reply. I know in theory you want to run everything on a different circuit, but I’d like to know the reality
Jason,
If I were to summarize what I have read on the topic. It would be that its good to isolate your controller off of the same circuit that your vacuum is on. I have mine plugged into 2 separate circuits as I was noticing a slight flicker on the screen occasionally when they shared the same one. Also the plug I used to auto turn on/off the vac & router did not work as well on the same one either.
Hope that helps!
-Alex
This help sooooo much! thanks alex! Sounds like I need at least another circuit
I also recommend separating your dust collection from your machine. This is especially important if you start bringing in a larger volume machine.
